but what about on the lid? backing plate or drill and tap...
I spoke with Mark about this today. There is a backing plate. It is sized and designed to slide up into that channel, taped to a stiff wire or rod. Go look at your deck lid, as I just did. This area does have an accessible channel. With fours holes drilled (Mark supplies the drill stop to prevent drilling too far) according to the supplied template, the backing plate is positioned to match those holes. Not showing in the photos is the fact that the backing plate, in addition to the three threaded bosses for attachment, has a fourth threaded hole. This allows the use of a small screw to be used just to hold the backing plate in place once your wire placement gets it where it belongs. This screw is then covered by the shock pivot plate.
He said several owners with Delta wings have already used this setup, and it does just fine. He said it is not really pushing the deck UP so much as it is pushing it OUT and away from the hinges. Says there is a good dampening effect on raising and closing.
He has them in stock and ready for shipping.
He is also working on a rear billet upright, to incorporate a newer style 'cartridge' bearing system.
