It seems the 351W distributor is a mix between the C and the 302. The body fits the 302 and 351W 9.5 and 9.2 deck ..the shaft is .531 like a 351C and the oil drive is the same as the "C" but the gear is the same as the 302 less the inside diameter of the shaft ...WOW a couple of the Boss 302 trans am boys were looking for tach drive distirbutors ..oh well.
Thanks for your help
Ron
