Anyone know a source for Mangusta upper door weatherstripping? I tried NAPA and they couldn’t match it. JC Whitney didn’t have anything that looked close.
Thanks to Mike Drew, I just found out that early Pantera door seals will work on the 'goose. I had a spare that came with my push button and it fits well! I think that the rubber door scraper for the upper door/window frame will fit also. Thanks!
Recommendation ..buy a can of silicone spray and install them and then wipe them heavy with the spray on a rag a couple times so the doors close and dont kink the rubbers.
I sent a sample of the door seal rubber to International Auto Parts who deal in Fiat parts. They contacted me with a match. Part number is 82729 and sells for $3.55 per foot. This should fit the Pantera also. I had a spare for the Pantera from one of the vendors and it fit the Mangusta fine.
