Does anyone have experience with 'Dustless' blasting? Apparently it's water based with glass bead and a rust inhibitor. Supposedly safe if epoxied/primed within 72 hours. Looking for something that will get in the nooks and crannies after I finish stripping all the easy places to get to.
And once there, despite the best efforts to blow it all out, it may continue to seep out for years.
Hopefully this does not occur during the painting session.
Just something to consider.
Sometimes easy is not best. Wink
buy a small hand sandblaster from harbor freight,tape a pillow case or plastic bag[ if you need to 'see' what you're doing]around the area to be blasted to contain the media. works great for small areas ,minimal mess!I've done this inside finished and upholstered cars use a fan to help suck the fine dust out while working.
That's how all this started many moons ago. I was just going to freshen the engine, then the 'While I'm here, I might as well...' syndrome started. Removed the undercoat in the engine bay and rear end, sealed and painted fuel tank, etc... all the stuff that needs to be done while the engine is out.
BUT after removing as much undercoating as I could by hand, I sandblasted the entire area to remove what was left of undercoating and get in the 'tight' areas, plus also thought it would be a good thing for pre-painting, however, I'm still removing sand from rockers, B-pillars, rear frame areas and that's after massive vacuuming and blowing w/ air gun.
So fast forward to now and I've completely stripped the front end area, removed as much undercoating from the bottom and front wheel area that can be done by hand and almost done with the interior. I've come to far now to not do a complete and best that I can job, just not sure what's the best way to tackle the tight areas. Also, after I remove whatever surface material, I'm wiping the bare metal with Ospho to preserve it
I think the dustless blasting you refer to is generally called Vapour blasting or water/glass beading. Done in a cabinet like for media blasting, however has a water pump pumping a solution of glass beads that suspended in water to blast the surface to renew the outer metal. It takes virtually no metal and leaves the surface as original. Unlike bead/sand blasting when you touch the metal it does not leave an oily mark. Some finishes may be a little more shiny than original, but these quickly fade with use.
Here's a Pantera being stripped with the hydro blasting dustless blasting method. Just be sure to wash down those bare panels with phosphoric acid or hydrochloric acid as soon as you're done to prevent flash rust and protect the bare steel.
https://www.youtube.com/watch?v=xFibV_tc32U
Maybe someone can explain how to embed a youtube video in a post here. I tried and couldn't get it to work.
