So I want to fit a holley 670 ultra vac. sec. avenger (and perhaps later a mild cam) with the stock air cleaner and keep it under the stock screen. To fit the holley to the stock intake I have had to fit an adaptor plate which makes the setup too tall to fit under the screen.
So I decided to buy a Edelbrock performer 4V which theoretically is the only intake that should keep it all under the screen and at least match the stock intake for performance on the stock engine. Upon inspection the port sizes are close to the same as the 2v and appears to be quite a bit smaller than the stock 4v.
So I had this idea that maybe if I ported the edelbrock out slightly, perhaps 2mm around each port and as far in as I can reach with the die grinder. Also I was going to remove part of the plenum splitter and remove some material in the plenum area to add a little volume. I was hoping that this would improve some of the top end performance and still keep the low down torque.
Alternatively I could just leave well enough alone as one would hope that edelbrock did their homework and found that their manifold performed better than the stock 4v even if their ports are puny????
Or I could just get something else? Keep in mind it needs to be the same height as stock. Something that is readily available. I was looking at the blue thunder but it appears slightly too tall.
Ideally I want it to still be driveable and have good 2nd and 3rd gear performance without having to wring its neck (nothing over 6000rpm). The exhaust has also been improved with ceramic headers etc.
I've used the older Edelbrock F351-4v, which i think is the predecessor of the Perfomer, it had 2v size ports as well.
I used it as is, i did not port it, Edelbrock's instructions stated it should be used as is and the port mismatch was a very deliberate feature that resulted from their extensive dyno testing.
I imagine the same is true for the Perfomer.
The F351-4v i used as is was brutal, it had good throttle response low down and was terrifying when you got the revs up.
Don't port the Performer unless you are experienced at manifold modification and know EXACTLY what you are doing, otherwise you could stuff up a otherwise very good manifold.
What has already been written is true, Edelbrock specified using the manifold "as-is", do not grind the manifold larger to match the 4V intake port inlet. Although the 4V intake port inlet has a cross-sectional area greater than 4 square inches, the ports "average" cross-sectional area is only 2.9 square inches. The opening of the port was flared open to operate with "wide open induction system" style intake manifolds, which was the trend in racing manifolds in the late 1960s. The 4V intake port entrance is about 2-1/2" tall, yet the runners in the factory intake manifolds (and the Edelbrock manifold too) are not nearly that tall, they are closer to 2" tall. So the factory intake manifolds flare open to match the height of the 4V intake port entrance. If you can visualize this, the gas flow in the factory induction system starts in a runner with a cross sectional area of about 3 square inches, then it expands to a cross sectional area over 4 square inches, then past the intake port entrance it returns to a cross-sectional area closer to 3" again. This is not ideal. Basically, Edelbrock designed the runners of their Performer intake manifold as if the 4V intake port did not flare open at the inlet. One way to make the cross sectional area more consistent would be to fill the intake port inlet to match the Edelbrock manifold. Filling the inlet of the intake port about 1/8" on the left side, and about 1/2" on the floor, gives the intake port a more consistent cross-sectional area (the average cross-sectional area is reduced to about 2.7 square inches) and makes the port smoother, eliminating the bumps and ramps built into the ports entrance. The other way to achieve a more consistent cross-sectional area is to use the Blue Thunder manifold, which has full height runners that compliment the opening of the 4V intake port; the Blue Thunder manifold was designed to be a "wide open induction system" manifold, which is why it was originally available with a carburetor mounting pad designed for 1050 cfm Holley dominator carburetors. It works very well with the iron 4V heads.
The small carburetor you've chosen will limit the volumetric efficiency of your Pantera's motor, it makes no sense at all to cut down the plenum to improve high rpm power, but at the same time restrict the motor with a 670 cfm carburetor. The size of carburetor you selected indicates to me you were concerned about low rpm drivability, if that's the case a full height plenum divider will compliment that choice. As far as I'm concerned, a full height plenum divider compliments the reasoning for choosing a dual plane intake manifold in the first place ... optimized performance at the rpm most often used when driving on public roads.
One way to gain horsepower at all rpm (about 25 to 30 horsepower on top) is to block-off the exhaust heat passage built into the intake manifold, if the winter weather where you live will allow this.
-G
Thank you very much for your responses. So I took the advice and fitted it as is but ran out of time to get her started tonight. I should have it going tomorrow and I will let you know how it goes.
As a matter of interest, the stock manifold and 600 vac. sec. weighed in at 25kgs(55lbs). The edelbrock and street avenger ultra weighed in at 10kgs(22lbs), quite a difference.
I have it all fitted up with still a little fiddling to do but wow, what a difference. It is as said earlier brutal through the low gears now and I am very pleased with the result. Quite impressive indeed for a stock engine and now I know why you guys like these cars so much. Thanks again for the good advice.
On a side note it would have been good to know what it was like with the factory carb and intake. Unfortunately one of the emulsion tubes was bent beyond repair and there is not an abundance of spare parts for 4300D down my way.
