Simon
![denisc denisc](https://pantera.infopop.cc/displayAvatar/user/1598208419506248/fod/1598208419507363/imageType/SQUARE_THUMBNAIL/1598208419506248avatar.jpg)
Denis
And, speaking of the Maserati Gibli, I also saw this block used on one being restored in a shop I was touring.
Get a new terminal strip from Pantera Electronics.
http://www.pantera-electronics.com/isc.htm
![](http://www.pantera-electronics.com/index_htm_files/40121.jpg)
This terminal strip/block has actual metal pads that clamp the wire when the screws are tightened so you don't break the wire strands. It makes for a much more secure connection - physically and electrically!
Richard.
Richard
Plumbers flux is an acid while electronic flux is rosin.
Plumbing flux is generally not advised for use in electronic applications due to its greater susceptibility to corrosion of the connection.
My 2¢
It may just be a "potential" for additional corrosion that doesn't actually materialize in real world experience.
I would venture that using plumbers flux as a cleaning process as you do may not create any issues.
However I would STRONGLY suggest never using an acid core solder for electrical work. Make sure you have a rosin core solder for electrical connections.
quote:if you want to stay original a good way to make sure you don't cut through the wire strands is to solder the wire ends it makes a soft but solid base for the screw to bed itself in.
Excellent idea Richard! I hadn't thought of that.
quote:a great way to clean the wire strands before soldering if they are oxidised is to fan the strands out then gentle heat them with a flame and then while still hot dip the wire into plumbers flux, they come out like new!
Another great tip!
Thanks!
This is the nicest option, with the metal pads inside the clamp..
These blocks where build for SOLID wire in the first place, and that is where they are used for i.e. House wiring set up. They are NOT ideal for car wireing.
To solder the car wire (which is build up by severall thin Cu wires in NOT A GOOD IDEA, as the solder material will creep under pressure fomr the screw, hence loosening the wire, bad contact.
Good is to cover the leads with a bushing (see picture)
I thought I knew most electrical terminals, but that is a new one for me.
would you have a "name" for that one?
edit...never mind, i found them
"Twin Entry Wire Ferrules"
quote:it just seems to me that in replacing the terminal block you would want to replace it with something more appropriate for the job i.e. 30A fully insulated/covered junction box or auto specific connector/socket
True. In hindsight, I probably could/should have replaced the junction block with a Molex type connector. Although I have no doubt that the terminal block I used will fare better than the half melted original terminal block.
As usual the Internet and YouTube comes through to provide why we Yanks have never heard of them. These are quite common (generally required) in Europe and in Asia, but USA manufacturing requirements do not require their use on our products.
Here is a link to a YouTube video that makes things much clearer.
https://youtu.be/os66cID30Ek
as I rebuild 4907 everthing which might get splashed by water (if ever) is set up by AMP super Seal. This is high end car stuff.
Should be avaialbe in the US.
They come in different desings vom 1 to 8 conections, and support 0.75 - 1.5 or 1.5 to 2.5 mm*2 wires. connector is fully water protected. One uses either the yellow seals or the red seals dependen on diamter of wire..
Use WD40 or spray vasoline to protect the wiring connection.
never a problem whit doing it this way.
Simon (from the wet The Netherlands)
I found almost exact terminal blocks at an electronics store. Cut to fit number of connections you need! I forget how many connections actually come on the huge block.....but it was a lot.
I'm still using my original blocks just fine. Of course if yours are corroded, replacement would be a good thing!
Cheers!
Steve
DICK RUZZIN
What you describe is "tinning".
I found one side of my car "untinned" and the other side tinned....!!!!
50ish year old hand made Italian cars.....go figure!
Ciao!
Steve
I know this is an old post......but wanted to illustrate the different sizes of junction blocks that are available.....from my collection! My recent post of "parts for sale list" knocked the cobwebs off of this issue!
In the pic's there are three blocks, the middle one I believe, is the original GOose block for one of the turn signal assy's. Like I mentioned, I found something VERY similar......but apparently used or gave the rest away...... haven't completely unpacked anything in the shop....so chances are good.....they will be found, if they exist.
I can also stop by the electronics store and check out their inventory!
Sizes listed are the width in pic 1. In second pic, where the blocks are on their sides, the dimensions do not apply, BUT you can see the difference in the sizes of the holes!
I believe that a Pantera ignition switch might take the larger of the three blocks here! There are some good sized perhaps #10 stranded wires on some of those connections! This large hole block would be too big for the simple light wiring circuits.
As I look more closely at the large one on the right, I can see where this does NOT have the little shields in the holds to prevent the screws from shredding the stranded wire. I believe this to be for solid copper wire......or better applied perhaps?
Upon closer examination, it might appear that NONE of these three blocks has the little tab designed to protect stranded wire damage.
Go figure! Gotta swing by the surplus store now!!!
Steve
FWIW, I usually solder the ends of stranded wires before inserting them in any kind of screw clamped blocks.
