I've installed an electric choke on my Demon Carb, I am just wondering were I could get a good switched +12v source from the back of the car. Dennis "A little shaken but not stirred"
George Can you explain to me how the elctric choke works, do you need to switch of the power to the choke off when it has warmed up or do you leave the power on all the time? Dennis
Keep it powered full time while the motor is running. Its just a small electric heater, it generates a bit of heat, enough to make the bi-metal choke actuator open the choke within 1 to 2 minutes. Nothing gets cherry red hot. Its not enough to fry any parts, create a fire or anything like that.
