You might want to check the back of the fuse block. Although the fuses are ok, sometimes the conncetions on the back of the fuse block are corroded, loose and just need to be replaced.
Originally posted by panhe:
does anyone out there know what can cause thok l e radio and the a/c to cut out intermittently?fuses are all ok ,any info will be appreciated!
