Not only check the fuses but also the tension on the fuses. Also, many times the problem stems from a bad ground. It wouldn't surprise me in this case since the headlamp motors draw a fair amount of current. The common ground is up under the dash behind the steering wheel. This is when you find out just how "bendy" you are!
