I have my engine out and will be installing a bolt in cross member under the oil pan. The emergency brake bracket also looks like it has to be converted to bolt in as well. Does anyone have any tips on how this is done? Do I remove the spot welds and re-attach the bracket
with bolts threaded into the frame rail? Thanks!
