I just took my original 50 year old break cable out and this is the way it lays down!
the long side is on the passenger side
There are two bendable tabs on the center brace of the frame to hold the cable in place as well..
![IMG_0451 IMG_0451](https://pantera.infopop.cc/fileSendAction/fcType/0/fcOid/26530111260295937/filePointer/26530111261065670/fodoid/26530111261065665/imageType/MEDIUM/inlineImage/true/IMG_0451.jpeg)
![IMG_0453 IMG_0453](https://pantera.infopop.cc/fileSendAction/fcType/0/fcOid/26530111260295937/filePointer/26530111261065671/fodoid/26530111261065666/imageType/MEDIUM/inlineImage/true/IMG_0453.jpeg)
Both cables held by the bracket, mounted on the transmission,
![IMG_0455 IMG_0455](https://pantera.infopop.cc/fileSendAction/fcType/0/fcOid/26530111260295937/filePointer/26530111261136761/fodoid/26530111261136759/imageType/MEDIUM/inlineImage/true/IMG_0455.jpeg)
![IMG_0456 IMG_0456](https://pantera.infopop.cc/fileSendAction/fcType/0/fcOid/26530111260295937/filePointer/26530111261165153/fodoid/26530111261165151/imageType/SMALL/inlineImage/true/IMG_0456.png)
and from there (off center therefore the long leg) to the speedo cable, and then turns through the hole in the inner fender (on the picture the new rubber plug / grommet)
Driver-side - same way following the inside of the frame rail, and then turns in to the hole..
![IMG_0454 IMG_0454](https://pantera.infopop.cc/fileSendAction/fcType/0/fcOid/26530111260295937/filePointer/26530111261110336/fodoid/26530111261110334/imageType/MEDIUM/inlineImage/true/IMG_0454.jpeg)
hope this helps
