FYI, Found a bad wire (burnt) in the yellow connector for the headlamp relay. Got that fixed, new ground. I have a bad wire (yellow) somewhere in the loom across the dash for the turn signals. Made a clean, soldered splice (fused) from the key on (yellow) and conneceted it to the yellow wire within the red connector. Also, added another ground from the neg. side cable where it bolts to the brakes box, ran it into the car and bolted to the steering colunm support brace. I think I'll add a couple more grounds just to be safe. All the newer cars have allot of redundant grounds...hmmmm
