Just a update on the rebuild , I have checked the timing, re-torqued the mains, rods an heads, but was again AMAZED by finding that on my regularly driven car ( about 500 miles a month )
that a bronze gear was installed on my distributor. I contacted "Comp cams " and the tech department said "I would check that bronze gear every 100 miles!, furthermore you should install a Melonite iron gear sold by M.S.D., this will all but eliminate the gear wear." Why, Why, would an builder short-cut this obvious mistake, a mistake that would leave me stranded or worse since I have a crank trigger, starve my engine of oil!
I thought I could trust this company, we were very friendly and frankly I am so disillusioned I am gust disgusted. Do not trust any body, build it yourself!
