Jack, thank you for your advise on prepairing the engine for "ground-pounder engine". From reading your past advise to other Pantera owners, I respect your knowledge on the Pantera engine. If you would share some of that knowledge with me so I can upgrade my engine I certainly would appreciate it. Please feel free to e-mail me at rmarconi@abhengineers.com, thanks.
Originally posted by jack deryke:
Regardless of what cam, pistons, intake etc you use, the very first thing you should do is build a solid foundation for the power. First, a 10-qt oil pan with baffles & custom oil pump pickup for your stock pump ($500) and a removeable rear crossmember to access the pan (Can do this at home or buy a kit).
Second, pull the lower cover on your ZF and safety-wire the ring-gear bolts ($35/kit).
Third, add a Milodon or SVO oil pump driveshaft between the pump & distributor ($20). While you're at it, add a second small roll pin inside the original one to stiffen it up & prevent breakage on the road ($0.12)
Forth, add a late factory water temp gauge (they're sometimes available used) and new sender ($6.95) for more accurate readings, and a cheap mechanical oil temp gauge ($18.95) on a tee fitting at the back of the block. The cheap oil pressure gauge will show real pressure while the stock one can be used as a type of 'idiot-light' as its always low. Last, add GTS headers and either GTS or other larger dia muffler set; the stockers are a little restrictive for big power. Now you'll be ready for that ground-pounder engine!
