Does anybody have a picture of their evaporator on a bench where I can see what the connection lines should look like. I am thinking mine has had an extra tight turn added to it.
Here are the input and output tubes of the evaporator in the car. Your output tube is definitely bent. It looks like someone dropped it accidentally and bent the tube. Since it is out of the car it can likely be repaired as Larry suggested.
joules"Racing is Life, anything before or after is just waiting" - Steve McQueen
There are usually a few floating around for sale, it's not an item everyone needs. Mike Mayberry has had one n eBay that hasn't sold for $24, that maybe an easier starting point, or replace with a modern one and upgrade your AC.
