I am in the process of cleaning and repairing the fiberglass luggage tub that slots in above the transaxle.
At the edges where the dzus clips screw in, is there a rubber seal or trim around the edge of the tub?
Mine has carpet that is glued and folded under the edges, back and both sides. At the front, the carpet has black material sown to it. Should this material be on the sides and back also?
Is there supposed to be a rubber seal that fits over the front most edge so it seals against the trunk lid?
