Enjoy!
quote:Originally posted by Brutus:
Very nice assembly and sounds......Is it possible to show pics of how you support your " mufflers " ?
quote:Originally posted by Brent:
and one more post since I can't seem to figure out how to add more than one pict!
quote:I like your adapters. I don't think they are wrong but I am thinking that the mufflers have to move with the engine movement otherwise the weld on the collector flanges will eventually fatigue and crack.
quote:Originally posted by garth66:....... Therefore, the collector flanges should not fatigue and crack since the exhaust, engine, and ZF are all joined together and move together, as one unit.
quote:Originally posted by garth66:quote:I like your adapters. I don't think they are wrong but I am thinking that the mufflers have to move with the engine movement otherwise the weld on the collector flanges will eventually fatigue and crack.
Note that the engine and ZF are joined together with a whole bunch of bolts and will move together as one unit. If they're moving independent of one another or in different planes, then you have a whole lot worse problems than the risk of the exhaust flange cracking. Therefore, the collector flanges should not fatigue and crack since the exhaust, engine, and ZF are all joined together and move together, as one unit.
quote:Originally posted by JFB #05177:
I love your setup and the detail (already stated the sound was awsome).
as for the brackets at the end of the ZF supporting the muffler. I believe Brent stated they do have "flex" so in effect they are a "spring". with the mufflers unbolted, I expected the end of the plate could be pushed by hand (~100 lbf) at least a 1/4". the incorperation of the slight bend should also allow for for some vertical thermal growth.
assuming there is about 40" from the end of the block to the bracket, and assuming an extreme hot exhuast of 1000F, the flange will have to give about 0.006 X 40 X 1000 = 0.24"
