Oil pan:
Red car:
Black car:
quote:Originally posted by DOES 200:
I know I brought this up before, but I still find it perplexing why the oil level shows so high on the sticks for my Fontana block Panteras. Red car has a 417 Fontana block build and my black car has a 427 Fontana block build and both cars have a 10 qt oil pan. It just came to mind again because I am changing oil on my black car and it brought back memories of the oddity. Oil sticks are the correct length too. I get concerned that I am putting in too much oil, but maybe I should just let it go and add my usual 9 qt and accept that it is correct. Photos below show the red car and black car oil on the stick after filter change and adding 9qt (that's even after letting the cars sit for 2 weeks the level is the same as shown). I wouldn't think it has anything to do with the fact that they both are Fontana blocks, but its odd that both are and both cars show overfill on the stick.
Oil pan:Black 5S oil pan by JanDaMan, on Flickr
Red car:9 Quarts In Red5S Gives This Level To First R In Warning by JanDaMan, on Flickr
Black car:ITSWIKDStickAnd9QT by JanDaMan, on Flickr
... I was wanting to hear from others what the clearance between oil level and "crank circle" should be. As I recall I never got a "rule of thumb", with desired level varing based upon engine use ...
The oil level should be below the windage tray. Even the factory cobra jet oil pan has a windage tray. The windage tray can't prevent windage if the oil level is above the tray. Obviously the windage tray has to clear the reciprocating assembly. How's that for a rule of thumb?
quote:Why don't you ask him to make a couple of correct sticks for you when he does his?
quote:Originally posted by SF:
Does the engine blocks has the same deck heigt, 9,5 or 9,2?
quote:Originally posted by DOES 200:quote:Why don't you ask him to make a couple of correct sticks for you when he does his?
Yeah but if I eventually sold either car it wouldn't leave the new owner anything to be puzzled about. Don did say the stick could be fixed though to match the engine 10 qt level. Probably the proper thing to do, but I can live with it as is because my real concern was the proper oil level. Tara at Hall also said the amount should be 9 qt (8 in the pan one in the filter). I figure it is their engine and their pan so they should know. I am ok with 9 as I know there are questions out there too about 10 qt pans really taking 10 or 9 and on my changes I have usually put in 9.
I am from Ithaca so I know the cold & snow and kind of miss it all. Here in CA its the same old same old basically year round. As far as Tara, she called Tommy Hodges too since he did a lot of work on that car and he confirmed 9 qt goes in. I am glad I am retired and have all the time in the world to fart around, because pouring oil into that car takes about 15 minutes per quart with the small entry at the valve cover. Put it in too fast and it spills out. But like weight training, I rested in between sets at half quart and each quart, ha ha.Oil Input by JanDaMan, on Flickr
Here is the black fancy cover on the valve cover. I will leave it as is since it looks pretty and with the small hole it takes my oil change into several hours so it gives me something to do. Now onward to brake fluid change. Had to take a beach cruise today in the convertible though for a break.
Yeah I can visualize the hot tub scene you mention, with hot babe & steam coming off the water with NY snow all around. Sounds pretty damn good to me.427 Fontana Aluminum FE Engine by JanDaMan, on Flickr
quote:Originally posted by LF - TP 2511:
I have preached this previously but for those that missed the sermon.
If you have confirmed that your oil dipstick is the correct length (there is a TSB that outlines this) and there are no modifications to the dipstick tube (not something that I have ever known anybody to do) the correct oil fill level is exactly the same as it was when that Cleveland engine left the factory. Oil level is based on a vertical measurement of the oil in the pan, not in anyway linked to the number of quarts of oil in the pan.
You can install any oil pan you can find, you can listen to whoever wants to label that oil pan as an 8 quart or a 9 quart or a 10 quart oil pan, you can get all the advice you wish from all the people you want to talk to. You can add remote oil filters, oil coolers, and 10 feet of oil hose.
The bottom line is that the fill line on the oil dipstick is the level your oil should be at.
But feel free to make this issue as complicated as you wish.
quote:Originally posted by over50:
I had the same questions on my car that came with a Hall pan. I finally concluded that the pan was designed for 10 quarts but still wasn't 100% sure that was right.
Does anyone know for sure how far the oil level should be below the surface on the front of the block that the tube goes into? If I knew that, I could measure the tube and dipstick and know for sure where to mark the dipstick.
quote:Originally posted by over50:...I would like the Cleveland measurement frmm the block hole down so I can double check. ....
quote:Originally posted by JFB #05177:quote:Originally posted by over50:...I would like the Cleveland measurement frmm the block hole down so I can double check. ....
This is what I gathered JUST BY READING the TSB. I don't have an engine to verify any of this
quote:I would like the Cleveland measurement frmm the block hole down so I can double check.
quote:I don't think that the dipstick and tube on my Cleveland are stock.
quote:I guess I need to know if the tube bump should be even with the block surface
