I have been rebuilding my brake calipers for quite some time. I finally have things back together. In the process I replaced the master cylinder with a Ford aluminum version that I know many of you have.
Before you ask, yes the brakes have been completely bled. All the seals have been replaced including in the master cylinder. The issue is that the pedal must be pushed a fair amount before the brakes engage. Is this normal for this master cylinder?
Steve
