Very nice! Care to share some more details about it?
Respect! Looks amazing. Pls share more details
Is it done? Are you driving it?
Congrats, it looks great!
rocky posted:Is it done? Are you driving it?
The car is being finished up at this time at Panteras By Wilkinson. I test drove it a few weeks ago. Practically every part of the car was modified/touched. Custom hood and decklid were necessary as well as boxes cut into the wheel wells to clear the heads. Cooling pack size caused the trunk area to be modified. The motor is a 2006 Ford GT crate motor and the stock ZF with an additional of an overdrive 5th. Dual disc clutch is used. The car is modified so the transaxle slides out the back. The rear window was modified to be removable with fasteners and a bubble placed in it to clear the supercharger pulley. The firewall opening enlarged to get to the wide engine. Dual connected gas tanks of about 27 gallons and able to be fueled from either side.
The interior has custom SPARCO seats made for the 2005 Shelby show car. The are essentially Ford GT seats that have been cut down. Interior is matte carbon fiber from Wilkinson and the steering wheel is matte carbon fiber from NRG with a quick release. Backup camera is necessary as the decklid was raised in the middle to clear the supercharger.
Currently In the process of trying to get Collector Car insurance on it.
gtpowered posted:... Custom hood and decklid were necessary as well as boxes cut into the wheel wells to clear the heads. Cooling pack size caused the trunk area to be modified. The motor is a 2006 Ford GT crate motor and the stock ZF with an additional of an overdrive 5th. Dual disc clutch is used. The car is modified so the transaxle slides out the back. The rear window was modified to be removable with fasteners and a bubble placed in it to clear the supercharger pulley. The firewall opening enlarged to get to the wide engine. Dual connected gas tanks of about 27 gallons and able to be fueled from either side.
The interior has custom SPARCO seats made for the 2005 Shelby show car. The are essentially Ford GT seats that have been cut down. Interior is matte carbon fiber from Wilkinson and the steering wheel is matte carbon fiber from NRG with a quick release. Backup camera is necessary as the decklid was raised in the middle to clear the supercharger ...
Wow! Sounds amazing...Please post more pictures and details on the build.
I am "Blown Away"
Wow! looks like an awesome build!
Did You make the Gas Cap or get it from one of the Vendors?
Would like to see more pics..
cuvee posted:Did You make the Gas Cap or get it from one of the Vendors?
Gas cap is a motorcycle cap sourced by Wilkinson. It was not vented so I had to get a vent with check valve for each gas cap.
Very well done! Looks fantastic in there and I bet it goes as good as it looks!
What Seat Belts are You using? I've been looking to replace my worn Belts on My 73 without having to Modify anything.
The seat belts are 4 point. Wilkinson had them made. I don't remember the supplier.
