I'm giving you guys first chance to buy this manifold before I put it on eBay. If one of you have been looking for this manifold, here's your chance.
This is the manifold cast by Edelbrock for Ford, it looks like a Torker manifold but the runners have been resized for the M-6049-A3 cylinder heads. This was the only manifold cast specifically for those heads. It is not to be confused with the manifold having the same part number but cast by Jack Roush Engineering. The Edelbrock manifold was not cast in large quantities and is somewhat rare; if you've been looking for one you know they are hard to locate.
The manifold has never been installed on an engine, its a virgin. The manifold's external appearance is not "fresh looking" because it has been laying on the shelf for about 30 years unboxed, but it has never been used.
Because it is a NOS un-used manifold, I want $400 FIRM for it, plus shipping charges.
PM me if you're interested.
-G
It varies also from the Torker in that is has no heat choke crossover.
If you have a set of A3 heads, grab it while you can. These do not come up often.
I've seen them go for $800. This is a deal.
I've got pictures of mine I can post if George can't.
The molds of the outside of the manifold are the same as the Edelbrock Torker molds, with the exception of the Ford Motorsport logo and no choke provisions but the bottom 5/8" of the runners are filled.
The same with the plenum. The entire volume of the manifold is smaller by that dimension.
It will bolt up to the 4v heads and will work like the port stuffers do, but you won't have to worry about those things coming loose and rattling around in your engine.
