I just started on the air dam this weekend so it will be a while before I make a page for it. This is the general idea though. From here it will take a long process of cutting, grinding, fitting, welding 3" hammer, dolly, repeat. It will take some time before it looks much different:
The second photo has a side strip which will bring in the side shape.
Getting the fit around the fenders and duct pretty good. Need to bump the base to get it perfectly straight before welding on bottom. Will probably prime with Zinc so I can find the high spots with the file.
Then work the lights,a and tie up a few loose ends.
Looking at tying this to the belly pan and a piece to mold into the front wheel well to close off everything.
Priner just to find the high spots so I could bump them back down. I was thinking about it but I don't see it playing into the paint scheme I was thinking about.
I am dead in the water right now though. The ice storm knocked out power and this is the first time I have had internet since Tuesday. I got the laptop up on the generator for a little but I will probably be scarce for a while.
They are not expected to get power restored for some time. I just got the generator wired into the house which is a big help. We have been running off extention chords and gas fire places for the last 3 days but with the house wired we now have the house heaters up and running. We have to limit the current. ex: We can run the washer but not the drier.
In the 90's power companies started consolidating and cutting aboput 80% of their line maintenance crews. Back then the electritions we knew said buy a generator.
After years not trimmming trees and keeping up with the lines the outages get bigger and stay out longer every time. this is the 3rd time in the last 2 yearsa we have been over 3 years on generator and looks like we will be upgrading this spring to one which will pretty much run everything integrated into the house.
It may be a while before I get back here but I can still read the post on the black berry.
Gary
I was thinking of using the area where you mounted your lights as the inlet for brake ducts.
Or maybe I will just mount screens behind the openings.
I am also going to have to figure out a front plate mount of some sort.
The only possible location for a plate would cover one of the openings. I certainly dont want to cover the rad opening.
Front plates are the law in this state but most of the time they dont bother you. Some towns are bad though.
But then again, a black italian car with screaming 180's might be enough of an excuse to pull me over. Big Grin
I was thinking of using the area where you mounted your lights as the inlet for brake ducts.....
The early GT5's didn't have lights in the air dam, but mine does have attachment points on the a-arm for a duct, so I assume the original intent may have been for brake ducts.
A front license plate just ruins a Pantera's look. Check local laws in detail, we found an obscure amendment in NV to the effect that "if the car is not designed with an attachment point for a front plate it may be omitted and carried inside the car under the seat". The UK has stick on hood plates for such vehicles. Prior to the above NV regulation coming to light I considered scanning the license plate and printing onto vinyl or onto a good magnetic sheet, but I'm sure there's some law against copying a license plate though.
I agree the plate ruins the look.
I just dont want the excuse.
My wife used to have a 99GT Mustang that didn't even have holes for a front plate.
She got pulled over all the time for it.
The police basically said they didn't care the law was the law.
I was thinking of something like on this car that PI was selling.
I want something that I could remove easily if I had to . As you can see it covers the opening.
  • 20807GT53
