Getting ready to install the Ron Davis Radiator, anyone with a front-mounted A/C con deser, can you post pictures of your condenser and hose routing? mounts etc.
@Sharkey - It looks like there is form between your radiator and the A/C Condenser, is that correct? Why? I am in the process of installing my condenser in front and just want to know if there is a reason that I should do this also. Thanks, Larry
You have to seal the gap between the condenser and the radiator, so air is forced to flow through both. It’s only a thin strip of foam that’s placed around the circumference of the condenser.
Classic Air or Vintage Air. Never used one of Quellas rad, so get the dimensions prior to calling them. Build the hoses yourself. Buy the crimp tool and length of each hose size you need long w/clamps. No big deal.
