Here's a question;
Does anyone know what the size and taper on the front upper ball joint is? Is it the same as a mid '70's Mustang?
I came across a couple neat adjustable control arms for a Mustang that if the ball joint shafts are the same may be a direct bolt on to the Pantera, although I think you would have to be using the smaller 2.5" dia. coil over shocks.
This could allow more caster and work out a lot cheaper than the modified Pantera arms, especially if I add in the fact that I wouldn't need camber locks.
Thoughts anyone? Am I crazy, has soemone tried this already?
