I think it's a 5 on 4 1/2 lug nut pattern, not sure about the stud size.
But issue is offset, not stud pattern. I'm not sure everyone even measures offset the same way, so you probably need to know exactly what is meant by numbers you are quoted.
marlinjackThe Machinist #5723 AMARGOSA MACHINE 'Running on Empty- Middle of Nowhere'
I can confirm for sure that the pantera bolt pattern is exactly as Fords I.E. 5 on 4 1/2 the stud thread is 12 MM x 1.5 pitch. Because I used aftermarket Weld Racing wheels and had to order their special Lug Nuts (1/2" grip). Regards, Marlin
