0 ohm is full and 200 is empty. And mine reads full all the time. (full when full, when empty it reads 90 % full)
So should I add a resistance or maybe something is wrong with the sender?
quote:I measured the ohm to 88 between the + and the white/black wire.
quote:Originally posted by No Quarter:
Maybe you have one of them new fangled econoboxes? I've heard they don't use gas, actually you have to suck out some gas from the tank occasionally, it produces more than it uses?![]()
quote:Originally posted by jb1490:
and the red wire (hot with ignition switch) needs to connect to the tab at the base of that taller "tube"
