In the past, I have written against the use of a filter on the suction of a fuel pump, because the parts were simply not engineered to work that way.
Well, RobbMc Performance has just released a line of fuel filters DESIGNED for the suction of mechanical & vane type electric fuel pumps. These high flow, compact filters are rated to only drop pressure 0.5 psi at rated flow. BITCHEN.
http://www.robbmcperformance.com/products/filters.html
I think somebody's been reading my posts.
Anyway, you owners who want to run a pre-filter now have a good choice. And I'll have to stop nagging you.
  • Filter_Lg
check out this question & answer from another forum:
Question:
What is the difference between a pre and post filter?
Is it plausible to use a pre filter as a post filter?
or is the pressure drop too much? or is it filter size related (to large/small)?
Thanks in advanced
Choco
Answer:
A prefilter makes a great post filter as long as the micron rating is small enough. Our 40 micron filters work great as post filters.
In general, a prefilter is overkill when used as a post filter. A filter placed before a pump must be a lot freer flowing than a post filter because it is on the vacuum side. A post filter is on the pressure side and need not flow as freely to achieve the same number of gallons per hour.
RobbMc
