I just finished the restoration on my 72 and now my fuel gauge is not working. It worked prior to the tank coming out and being cleaned / sealed. I did make sure the sender arm was making a full sweep before I put the tank back in the car. I just want to make sure I rewired correctly. By putting a volt meter on the remaining two is there a way to test that the wiring is ok?
Thanks,
Toby
