Good Morning:
I am about to start two projects on the fuel system and wanted to see if you all had any hints/tricks/heads up for replacing:
1.) fuel filler hose
2.) Fuel Sending Unit
Fuel Filler Hose:
I have downloaded and read the instructions on this taks from pantera place. I was wondering if anyone has used the more flexible clear fuel filler hose that is often used in racing applications?
Fuel Sending Unit:
Before I take out the unit, I was wondering if I need to make any special accomidations like removing glass, etc to get the clearance needed to remove and replace the unit? Any other insights anyone would share before I start?
Thanks!
Khan
