Oops I got the system backwards. I used the 22MM for the input. 22MM is off the plug on the bottom of the fuel tank, this way you by pass trying to pull up the fuel to the pump.
For the return, there is a 10MM to AN (-6 I think) available but is it only in a straight connection (Metric to AN). I ordered mine from Summit Racing, I think the mfg is Earl.
