I have given up on my gauges.  None light up any longer, the tach doesn't work at all.  The oil pressure gauge goes from showing over 70lbs. of pressure to showing 0lbs. of pressure.  The water temperature gauge is all over the place, and the ammeter has already  been removed as a precaution.  I have a brand new set of gorgeous Speedhut gauges including a clock that are going to be installed for me starting tomorrow.  They even put the De Tomaso logo on the speedo and tach.  I can barely contain myself that I'll be able to see the gauges light up at night as well as be more accurate and less temperamental than the Veglias.  And the second temperature gauge that I had previously installed on the dash to the left of the steering wheel will now be replaced with a matching clock.  These gauges are beautiful, I just can't wait to see them on at night.  Pictures will come when everything is installed.
@tberg posted:
Check the Grounds!
