Rick,
You may want to re-direct your question to the ZF specific category below. You also can search there for similar past questions.
I'm considering the same issue as you are, and have found no low cost solution. I'd like to be at or below 5K RPM at 150 MPH, and it looks like gears in the low 3s (I think there are 3.40s?) are out there. But this looks like a $3K solution. The alternative is to change both the ring & pinion, and 5th gear.
The choice of approach probably depends on your goal for your car. The 3.40s probably don't launch like a dragster, but if you aren't worried about coming off the line hard, that may not be an issue.
I also plan to go to EFI, and I think that the low RPM efficiency an EFI system can add to a mediumly hot engine should make it easier to live with a higher 1st gear. I'd image that an 850 Holley with a big cam, doesn't work to well with 3.40s.
Ken
