Mooso,
My 72 Pantera with the dash 2 box has the taller 5th gear, .642 I think, from RBT. With my BFG 285/40-18 rear tires, I have seen 164 on my gps. My tach is not reliable, I have a 6500 rev limiter and I had not hit the limiter when I ran out of road. I have a 377 stroker that was either making 304 or 326 HP to the rear wheels.
Originally posted by mooso:
Building a high HP/torque stroker may get you to top speed quicker, but 6500rpm is 6500rpm, right? So your top speed is going to be limited by the ZF gearing. I believe an early car is capable of maybe 150mph. What are the gearing options available and what can you expect from taller gears?
Mooso
