Some times it can be simple, make sure you have a high pressure cap on your expansion tank. The caps do wear out and then the unsealed tank can allow a lot of evaporation even a boil over.
I think Chris hit the nail on the head... If you encountered a hot engine situation for whatever reason - e.g. sitting in stop and go traffic with a marginal fan - you would boil out some coolant through the overflow. This would require you to later top off your system. And this is only exacerbated if your pressure cap is not performing properly.
And as others have already pointed out, the Pantera cooling system is not a closed or sealed system.
