I'm getting ready to refinish my 10" & 13" Campy's. Does anyone have a paint code for the "gold" color originally used?
quote:Originally posted by bdud:
I found the best color out of a rattle can was Duplicolor's Engine Enamel Universal Gold, DE 1604. I later had my wheels powder coated, let me know if you want details of that.
quote:Originally posted by Bosswrench:
Part of the confusion comes from the fact that some powder coatings cure at 350-450F while others cure at much higher temps. The higher the cure temp, the more likely you are to have coating quality problems. But either temp gives one the opportunity to simultaneously anneal the magnesium castings and relieve stresses, since that only takes a minimum of 275F for about 3 hours- low enough to do in your kitchen.
Powder Pro is not out of a shed or the couple of companies I called about powder coating magnesium. Chip actually works for one of those companies and does some as a side line, very nice work. I did not have anyone say they would not powder coat mag. Lots of motorcycle wheels are magnesium and even Eastwood talks about powder coating some magnesium wheel centers, http://www.eastwood.com/powderwheels
I wonder why Central Coatings do not coat magnesium they do say they coat anything that can withstand 450F, I think mag is 950F. Maybe it is just their choice because of the value of some of those wheels.
