Is there a preferred method for burping a goose? I have the rear end jacked up but I'm not sure if there is a better procedure... So far i've only gotten 2 gals of coolant in her...
Answering my own question here. I lifted the back end about 18" in the air, found and opened the air bleeders under the rad cover... About 1 minute later cool juice was coming out of them... I got an additional 2 gals in there... Total coolant/distilled water volume was right at 4 gals...
Have you tried a vacuum filling device? It pulls a vacuum in the system then draws the coolant into the system. Works great and you won’t have any air bubbles.
Where would you put the vacuum & where would you fill from? Sounds logical if done right...
Go to YouTube and search for “vacuum coolant refiller”. There are lots of them for sale on Amazon. I recommend Pantera and Mangusta owners buy one with a vertical vacuum gauge.
