@rocky posted:
Can someone help us keep the players straight?
Muttsjet - 8MA0642  Car Done?
Lee - 8MA???? Car Done?
Mike - 8MA???? Car Done?
Maugusta - 8MA????  Car Done & Sold?
Thanks…. Hard to keep straight, but I know this thread is for you, and not me…
8MA-596
Switching from injection to Weber's. Easy right? Well, life got in the way and I probably can't touch the car for the next 6 months. When I do get back to it, probably have 3 months of work to do. Otherwise the car is in decent shape.
Ready to reassemble drivers suspension and steering. Can someone confirm best grease to use for steering and how much to put inside gaiter? What is the grease gun attachment called to put grease in heim fitting or should I just get the small grease gun for filling heims mentioned in another thread? Confirm RERS 5 is the correct rubber covering for the front steering heims?
  • steering
   If you cannot get the original Italian stuff, the owners manual calls out precisely the use of "MOBILEGREASE SPECIAL" for the front bearings and steering rack...Another fine substitute is whatever you have (!).
  So whatever cool stuff PepBoys is selling for wheel bearings, just make sure the heim is cleaned of all old tarnish and then spend some Spa time working the new grease around the joint. I think there is really no point in overpacking inside the boot, work enough to cover the bearing and avoid a grease aquarium.
   Getting the boots over the heims is super simple. Finish by inserting the alignment spaces and voila, good for another 50 years.
@leea posted:
I used a heat gun on the Heim boots to soften them up...  Didn't take long...  The boots went from a matt finish to shiny when heated, then slipped right on...
I agree with Lee that choice of grease inside the rack may not be that critical...  The steering shaft isn't exactly spinning at high rpm and heat build up is probably not a concern...  Just keep it lubed with SOMETHING and you should be fine...  (In my opinion ~ FWIW)
MH
I think on page 18 of the owners manual, it says to replace the grease when the rubber boot crystallizes to plastic and then breaks open....see even older comments on this from smart guys who wondered why DeT used just half a boot (!) But yeah, its hardly as if there is going to be a lot of rotation inside the heim.
The best picture I can give on installation of the boot is attached, the sequence is;
- put the Heim threads thru the small hole.
-take the rod you'll attach it to, scrunch the rubber up enough to catch the thread.
- make a big pull. Rubber is magic.
  • birthing heims
Back to work after some elderly parental issues...
So, steering rack heim off and regreased with grease gun. Have heim boots and special pliers to get heim boot on.
Am curious, since my jam nut is welded to the large circular metal disc, and I had to remove this jam nut combo from the heim joint to get the jam nut combo into the end of the boot (heim would not fit thru small opening on boot end), is it hit and miss to get it all reinstalled to same location?
I did take some measurements before I disassembled the heim to jam nut/metal disc combo: given the placement of the jam nut combo on the heim joint thread, it took exactly 18 full turns of the heim/jam nut combo to get it off...the distance between the outer edge of the jam nut and bottom of inside edge of the heim body was 16mm...the distance between the inside edge of the jam nut and outside edge of the heim body was 56mm.
....as for the wheel bearings....
The Ferrari procedure speaks some truth, but final torque is WAY wrong...   Since you are using "Mustang/Ford" wheel bearings..... I'd go with that procedure in the Ford books as well!
Pantera procedure is close to what you want to do......butt IMHO way too much subjective feel....and GOING AMISS!
Mutt....... you should really go in and just delete those references in your post. Wouldn't want to mislead anyone....Ferrari or otherwise!
BELOW EDITED 8/14/2024 1PM PST
The initial torque tighten 17-25FTLBS WHILE SPINNING THE ROTOR to seat the bearings.  Loosen 1/2 turn retighten 10-15 INCH LBS while again spinning...  This amounts to pretty much "thumb tight!"  Use that new HF inch lb torque wrench rotting in the bottom of your tool box drawer!!!
These are tapered bearings, so they can handle a little preload.  12FT LBs IS TOO HEAVY!!!  Would likely burn up the bearings in short order!!!!  Don't need that!!!
Wrench on!!!!
Steve
Picture attached from 1970 Ford Shop Manual- Mustangs Cougars etc.wheelbrngtorq1
  • wheelbrngtorq1
.......I wouldn't go any higher than that in aluminum for a smallish bolt..... secure with at least blue loc-tite.....red if you expect to challenge the braking system on an hourly basis!        Don't want to break 'em or strip 'em!
Fun working on a car with absolutely NO technical references 'eh???    Pantera not even something you can refer to either!
If you can find one of those "torque" charts showing recommended amounts of tight for various sized of bolts, that can come in very handy, but looks like you may have that already!
Some of the factory Ford shop manuals had a section or page with that on it....just trying to think where else.....  Fastenal website could have it....MSC.....  Google if nothing else for a chart.
Gettin' there!!!!
Steve
