Just built aluminum gas tank with electric fuel pump. Nascar valve covers with oilers, heat exchanger and accusump installed. Getting closer to completion. Alex
Thanks for noticing, cutting corners on this job would not work. I feel the money spent will prove beneficial and make for one solid, fast car, which pleases me. I only want to do this one time so it is best to do it right the first time. Oh well, this sounds so cheesy I'd better get back to work making money for this project! I hope it's done real soon. Alex
