Finally installed engine. Still need to hook up vacuum lines and sort out ignition wires. Waiting for a custom made aluminum water tube with A/N fittings from thermostat housing to lower water tube. Once it's all put together, one final inspection and it'll be ready for engine start.
Check out the pics.
Alex
http://s461.photobucket.com/al...?albumview=slideshow
