Originally posted by Chris Wilson:
Hi all, just trying to locate the correct size bolts for the half shafts any help very much appreciated.
Cheers Chris
The bolts are aircraft grade AN7-12. You will also need the compatible elastic stop nuts as well. Aircraft parts suppliers can provide the right hardware.
Dimensionally they are 7/16-20 thread with a 11/16" grip length, 1 1/4" overall length.
Hi Chris,
The following is from Mike Drew in 2012:
The Ford parts book doesn't identify the size of the bolt; they are just called 'bolt'. The nut, however, is referred to by size--7/16-20.
Presumably the bolts are the same size; long-shank 7/16x20 bolts are also known as AN-7.
Aircraft Spruce sells perfect replacement AN-7 bolts in the appropriate length. The part number is AN7/11A. They cost a whopping $1.38 each:
http://www.aircraftspruce.com/catalog/hapages/an7.php
The matching nut is AN365/720A; they cost .86 each:
http://www.aircraftspruce.com/.../hapages/an363_1.php
The Ford parts book indicates that M11 split washers were used with the
7/16 bolts. M11 split washers are impossible to find, but nominally identical
7/16 washers (part number AN935C716, cost .49 each) appear here:
http://www.aircraftspruce.com/...ages/lockwashers.php
That should do you nicely!
Mike Drew
When you put the bolts back on, you want to slip them into the ZF flange facing out
