I am getting some backfiring through my carb which is a 670 street avenger ,I am checking all the usual suspects like ignition timing valve timing and running lean however I am not sure that the coil I have is the right coil for the hall msd distributor that I have ,which coil is the best coil to run with my distributor,tony
Hi guys ,all the parts are new as this is a complete rebuild of this car that I brought in a pile of rusty boxes (I must have been mad )anyway the car is almost finished and I just wanted to check on the coil that you guys recommend as I got a ready to run hall dissy and it came with a fairly standard looking black coil and wanted to check that in would not blow my distributor .i think the backfire is the result of my carb a Holley 670 street avenger not being set up as its new and I am running a torker manifold but on the advice of dan jones I am changing to a duel plane and setting everything up for that manifold … I will let you know how it goes tony
