I just got around to installing my Kirk Evans Quad headlights and they look great. Does anyone have a method to adjust the low and high beams so they are correct on the road or is it more a drive it and adjust to personal taste concept?
I assume a standard method would be something like put the car on level ground a specific distance from a wall and focus the beams at some height H lower than the height of bulb to give a predetermined downward angle and then some Y distance on the side angle? With the move to the quads the High and Low beam are obviously now independent adjustments too.
Thanks,
