I don't know what other application it has but it is just a double pole double throw 12 volt DC relay available at any electronics store. The coil ground connection is internally jumpered to one of the common poles but you could do this externally with a jumper wire. The only issue would be the mounting bracket but for $80 to $100 the vendors want I could find some way to mount it.
Good luck
Forest
