My headlight motor relay only lifts the lights, but does not retract them.
I've watched thru the clear relay cover and discovered the relay moves a little when the lights are turned off, but doesn't move far enough to contact.
Is there a fix for the relay, do I need a new relay, or is there a problem with inadequate current?
Or, is there an upgrade to the relay or circuit which may be a better long term solution.
Any help would be appreciated - especially on the electrical system!
Thanks, Rod
