Vintage Air makes parts that have been used by Pantera owners with great success. But you need to ask yourself what you expect from your 32-yr-old supercar. the stock controls work fine except for the heater shut-off, and that is better fixed with a remote manual shut-off, which corrects the factory controls inability to shut off of hot water through the heater/AC vaporator as well as the safety aspect of rupturing one of the two short hoses under your dashboard. Adding this manual valve from a hardware store and a thorough cleaning of the 'secret' filter screen in the side leg of the expansion valve under the dash, if combined will force you out of the car with cold-ness, with a completely stock assembly. If you simply want to change the appearance of this area of your Pantera, the late wide-body cars used vacuum operated controls from the Maserati Biturbo, which have dropped invalue like a rock in a mineshaft, so such parts are cheap
