When my car is cool, it rolls with little to no resistance from the brakes. After the car comes up to running temp I notice that the car won't roll after I park it as it did so freely before the drive. The brake lines and the master cylinders reside right above/next to my headers. I have a 428 FE big block so you can imagine the heat. My thought is that the brake fluid is heating up, expanding and pressure increases on the brake piston. What are your thoughts?
Thank You,
Khan
