Hey there
So I have a 72- needing total HVAC revamp-
The heater tubes that run through the shifter tunnel are
not in the best shape- I have researched replacement and it sounds like I may
need to pull the engine to remove/replace-
Is this really the only way? Does anyone have any tricks that maybe would work to get them out w/out
Removing the engine?
Also the cable from the dash temp handle Spears to have broken from the lever.
Any thoughts on a repair or do I need to pull the cable. I’m trying to avoid dash removal-
Thanks
Mark
