This part was with my wiper motor bracket and nuts, any ideas what it is and where it goes? Soft rubber filler 🤔
the rubber goes between the motor and the bracket. https://www.angclassiccarparts...-mgbgt-mgbgt-v8-6780
I had the same question, Jerry. But if you look very close at the photo, you can see the black gasket peeking out just a little bit below the base of the large bracket.
The gasket is holding the bracket off of the countertop.
I see it now, I did not have that mounting base. Looking at the impressions on that insulator it was in contact with the motor.
I felt it was too tight to the driveshaft and would be super noisey solidly mounted . So I installed a 1"+ thick rubber spacer. So spacing it seems very critical.
I guess I will use the insulator as a template and fab something simple, The mounting stud length should give me a clue to thickness. Unless someone has a thickness measurement or has one collecting dust
Likely removed and discarded (Why can't kids put things back where they belong?? 😁)
Sheesh,, (thefirstdomino)
Jerry
