I realize that this doesn't answer your question, but I can tell you where NOT to get the power from. There are numerous stories of people powering their choke from the coil. This acts as an effective rev-limiter and you will be unhappy with the results. You'll need to find another source.
Charlie McCall
1985 DeTomaso Pantera GT5-S #9375
"Raising Pantera Awareness across Europe"
http://briefcase.yahoo.com/gt5s_1985
Originally posted by jack deryke:
Some people have used the hot post on the back of the alternator as an effective power point. The disadvantage of course is that its not only unregulated, its un-fused. So if such things bother you, use an inline fuse of maybe 15 amps (not sure what wattage the choke heaer draws)
Thanks Charles and Jack. I had heard about the coil functioning as a rev limiter so needed another sourcr. Thanks for the help.
