Has any one ever installed a Holley 4-bbl throttle body fuel injection system
if so, how do you set up the cold start to run correctly
Originally posted by PANTERA1731:
I have the Holly Pro-Jection 700 on my 351 but it came with the car so I don't have an answer to this one, but let me know if I can help with anything else. I like it.... hasn't let me down yet. I could email a picture if it helps.
-Richard
Originally posted by mikep01:
if its the one that is adjustable with a lap top, connect the lap top and see what your readings and see what it is doing on the fuel map page. it sound lean so richen it up a bit. you can make adjustments on the fly at idle. if your in la i might be able to lend a hand.
Hi Keith,
Unfortunately I don't have the Holly software to load into a computer and check for you. It was programmed by the previous owner and I haven't needed to adjust it. I'm in Los Angeles, if you are nearby I'd offer to let you come by and check. Otherwise if you can send me the program I can get the info you need. I have the computer connector behind the passenger seat. Let me know if either way helps. Does Holly have any tech support?
-Richard
i to have the dos version. what i have found to work the best is to watch the fuel map\grid and see where the dot is floating around, since adjustens are made on the grid. its best to use to people, one drive while the other watches the laptop. what cam do you have, mainly duration at .050?? i found my cap was to big and was causing vacuum problems to the map sensor causing a surge at idle.
